hi,
Our CH is failing, its a pumped open potterton 80 with 4 rads upstairs and 4 downstairs and it has been working fine for 15 years.
The has alway been some air in one of the upstairs rads, it bleeding it has left it ok. However its been rented out the last 3 years, and tenants now tell us that upstairs has rarely worked, and now the heating has failed completely.
ok, checking the system. The boiler runs ok for about 5 mins, and the first radiator starts to warm up, and then the boilers cuts out as it does appear to be able to get the hot water out of itself.
Now when I checked the upstairs rads, that all appear to have a large amount of air in, and its very hard to bleed any of them to get water. The pump is spinning, and the pipes do get hot either side of the pump.
So I think air lock, and remove one of the downstairs rads to drain the system.
This is where it gets interesting. The system refused to drain (no water out), unless I released the bleed screw on another downstairs rad. All the upstairs rads had their bleed screws out.
Also the header tank level never went down at all.
about 10 mins after the boiler cuts out, you hear an amount of water returning to the boiler. (gurggle gurggle)
After all this I'm think either
1) Pump impellers are kn*ckered - Could change the pump, but if air caused it to run dry, then another set would fail.
or
2) Blocked cold feed. - how do I detect this , and/or fix it ?
or
3) whole system sludge up. - Is it worth hiring a power flusher from hss and going it a go?
Any other suggestions ?
or
or
