Hi Hoping someone can offer some advice...
Have a Baxi WM382 boiler which seems to work okay (pilot light is on). Yesterday heard some disturbing clanking noises then realised the radiators were becoming cold. I bleed the pump to start with, then noticed it appeared to be jammed. I have now replaced the Grundos 15-50 pump and it appears to be working. Despite this the heating is not working and now I have noticed the water is not heating either. All pipes to and from the water cylinder are cold. There is still an occasional clanking noise usually along with some gurgling. Could it be as simple as a valve jammed or is it likely to be more involved job?
Any help aprreciated!
