I have a Puma80 boiler servicing 7 radiators (3up-4down) and have just replaced some strange microbore plastic pipe which was throughout the CH system (from a bar we think 10mm Od - 6.5mm Id) with good old 15mm copper piping .
System holds pressure fine, rads are bled, but the rads do not get HOT only warm (and cool at the bottom) but even this takes ages.
The boiler fires for about 25 seconds before shutting off and the water circulates (slowly) through the system. Then about 2 minutes later the boiler will fire again. The pumps seems to be spinning and is set to 3 (centre screw check) and I can hear the water circulating in the boiler. The hot pipes from the boiler are very hot but the heat doesn't seem to be getting to the rads.
With all the valves open (not thermostatic) only one radiator gets hot, with them all partially closed this is when I get the warm only thing going on.
Is the boiler simply overloaded or should it be able to cope? Do you think the pump is not working at full flow? What's your thoughts fellas... I would like a nice warm house this winter...
