WB Greenstar 30CDi gas fired condensing boiler issue.
Internal diverter valve fitted.
HW working, CH not working
Happened possibly as a result of low gauge pressure. Even after I repressurised, CH still not working. Will the low pressure in the past, be the cause of current problem?
Yes, radiator valves are open.
No fault codes.
1) Move thermostat, boiler fires up, green light (flame led) comes on.
2) Sound of some sort of fan sound revs
3)Temperature starts climbing from 50ish in about 30-60 secs to 68,during this time the fan sound speed (RPM) is falling, and during the time temp is climbing, alternates flashing with -11- symbol. During this time there is a slight vibration from the boiler/and water in the pipes sounds.
4) Boiler flame cuts out around 69, causing the fan to sound then revs up again.
5) Temp continues to climb to 74/75, then levels off. I let it cycle a few times, but clearly it's not circulating the CH water though.
FAQ/google trawl suggests diverter valve problem. Any thoughts please?!
If you do suggest disconnecting the diverter somehow, please let me know how, as it's hard to know what each part is called! Also, if you'll suggest "Feel the CH flow pipe when a tap is run. (pipe on far left)" - where is that pipe??
I've tried the drain on the water pump, so it's not an airlock there.
Looking at faq page, I can't see a manual leaver for the diverter valve
No fault codes.
