My girlfriends heating has packed up today. The system is gravity fed from a tank in the loft.
When we put the CH heating on via the programmer the boiler fired up for a minute or so and went off. The pump was making a funny noise then. The pipe between the boiler and the pump was really hot but the pipe on the other side of the pump was cold.
I went down to B&Q and got a new pump, fitted it but still have the same problem. It sounds to me like the pump is empty when on (only air - making a funny noise) Ive tried bleeding all the radiators as they seem to fill up with air when the pumps on. Once bled there is very little pressure in them, ie little or no water comes out.
Ive checked the tank in the loft which is fill (a bit dirty) and the ballcock is working. However my guess is the water isnt feeding into the pump for some reason. Does this sound right? What could cause this, a blockage?
Could this be a blockage somewhere around the radiators? Also where is all the water going from the radiators as I have bled the raditors a few times to leave them fill with water.
Any further information required then just ask.
Thanks in advance. Trying to get it working before xmas!
