Hi all
I have a Vaillant Ecotec Plus 837, around 10 years old. The CH has been running constantly, and I thought originally this was a fault with the timer/thermostat (Drayton Wiser).
I have disconnected the external timer (Drayton heat hub), and fitted a used Vaillant mechanical Time switch 150 to the bay in the front panel. No change, CH still firing when 150 is in OFF position!
I have also removed a linkage between terminals 3 and 4, which my plumber installed when Wiser was removed. No change, CH still on.
Finally, I have removed the TS150 from the front panel, so there is no timer, thermostat or switch connected at all. CH still firing and rads hot.
I'm completely at a loss here, as there is no device calling for heat.
For info, the plumber has changed the PCB (with a refurbished one), which had no effect.
I'd be most grateful for your suggestions.
Thanks on advance.
Thanks on advance.
