Boiler is Ideal Classic FF360, the timer is a Honeywell ST699 and there is a Drayton MA1 mid position actuator. The problem is that when Hot water only is selected on the timer the central heating comes on as well. So I looked at the actuator and realised that it was not working and replaced it making sure that the wires were connected correctly. Great I thought as the actuator leaver moved when I selected central heating. Then I selected central heating and hot water and it moved to mid position. But when I put it to hot water only, it stayed in the mid position. When I disconnect the power supply the actuator moves to the hot water only position so the valve is free to move. Any ideas please.
