CH only works when hot water is on
20 Apr 2014
When I first turned the central heating on it came on with the timer but went off when the hot water had heated, the only way to get it back on was to run all the hot water taps so the hot water kicks in again. After about a month of this it started to work OK, radiators coming on until the thermostat temp was reached then going off then coming back on as necessary. I found 1 radiator that didn't get hot at all, so I bled it, which took ages as the air came out very slowly, now I have the same problem with the heating again. If I bleed the problem radiator very little water trickles out eventually although the radiator is hot, which concerns me.
Any ideas?
