CH pipe knocking
10 Apr 2021
During the winters I get pipe knocking when the CH is turned on.
I usually drain the CH down every 2 years, and add an addictive to help remove the sludge before draining and refilling a few times, followed by 300ml of inhibitor. There is no pipe knocking for 1-2 months then it starts up again. I am wondering what could possibly be causing the sludge. I suspect it is due to not enough inhibitor, but I am not sure. I have a 10 rad system, 6 of which are double panelled.
I used to think that it was solely caused by pipe expansion, but when the rads were on for 2-3 hours, stopped for 2-5 minutes and restarted the pipes would still knock so it can't be an expansion issue.
Have you checked the thermostatic rad valves? If the flow thr the valve is wrong way it can cause this issue
