- Joined
- 5 Jan 2016
- Messages
- 234
- Reaction score
- 8
- Country
Hi guys.
Looking to put some insulation over the 22mm main flow and return to my combi boiler in the floor void. I have lagged all the 15mm pipe runs with 13mm wall poly pipe insulation but i cannot get the same type of insulation to go over the main run.
The problem is the pipes are seated next to each other (flow & return) in the same notched out joists and also the are not seated very deep below floorboard height, So if i use 22mm pipe insularion it puts pressure on the chipboard flooring.
My question is, is there anything else i can use? I have seen some reflective foil wrap that i would be able to get around both pipes individually but not sure if that type is any good?
Thermawrap spiral wrap
Thermal conductivity 0.0047 w/mk
Thermal resistance 0.790w/mk
Anyone used this stuff in tight spaces?
