CH pipes running behind wood burning stove
23 Apr 2007
I'm having an old bricked up fire place opened up and a wood burning Morso stove installed with a flue running up the stack. Currently running across the old fireplace, in the corner against the hearth and the back wall, are a couple of CH pipes going off to a radiator in the next room.
-If there's space behind the burner can the pipes stay there?... is there a minimum distance between the stove and the pipes?.
-If there isn't the space behind the burner can the pipes cross through the stack higher up behind the flue instead.?
