I have been to a property with a primatic cylinder. Rad upstairs working ok, rads downstairs cold. Have bled them & ensured rad valves are open. 15mm pipework coming down to rads is also cold. Any suggestions on why lower rads are cold ?
Primatic so more than likely pumped heating gravity HW.
ON flow pipe from boiler there is usually an anti gravity valve (brass 3 inches long) these block up and stop correct flow going to rads.
Sharp hit with hammer can free them but support pipe with hand .
Cost about a fiver for new one
