Hi -
In the "How To - Problems associated with noises from the central heating system" section, it says that you can overcome constant humming in the pipes by fitting anti-vibration mountings to the pump. That's exactly the problem I have, made worse by two pipes being fitted so tightly together that I can't get a strip of rubber between them. My question is - where can I get these brackets? My local suppliers (South Hampshire, UK) looked totally blank when I asked them.
Any advice gratefully received!
Piet
Piet
