I have a baxi bermuda 552 gas fired back boiler. The system uses a Grunfos pump and a really knackered looking manual timer/controller with two toggle switches which offer timed, on/off - and water or heating priorities.
I recently turned the central heating on for the first time after summer. I noticed the pump frequently making a rattling noise which stops if finger pressure is applied to it from the left or right. The radiators get hot with no problem other than one rad neeeds to be bled. However, my main concern is no matter how I set the timer/controller toggles or the thermostat in the hall, the heating stays on. I have now turned the boiler contol right down just to prevent the system getting too hot. And, I don't seem to have a feeder/expansion tank in the loft!
Also, my copper cylinder has a thermostat near the bottom with an electric cable coming from it but it doesn't seem to make any difference how i set it, the tank still gets very hot even with the immersion heater turned off.
For information, over the summer I fitted a new mixer tap in the kitchen but thats the only change made.
Any ideas?
Any ideas?
