Hi All,
Hope someone has a clue..
Boiler: Ferroli Optimax HE31C
Thermostat : Drayton Digistat SCR with wireless RF1 unit
Timer/clock : Servowarm model LP111
The problem I have is that an engineer came out and moved said boiler from bathroom (!!) to the garage. In moving the boiler he has also moved the thermo from near the boiler and the timer from the kitchen so it's all sitting in the garage. The wireless unit is in the understands cupboard.
Since the move the boiler does not want to switch the heating off. It doesn't respond to the timer at all and I cannot switch the heating off through the boiler. The hot water works on request and I have had to turn the CH right down.
Fearing he may have wired it incorrectly he came back out and removed the timer from the equation. The permanent live is obviously still running to the boiler but now no timer connected.
He had a closer look at the board and there is a resistor that seems to have scorched on the card (it's completely black and has left residue on the plastic cover.
The boiler however has presented no fault codes and will allow me to change temperatures for both water and heating with no issues at all.
Any ideas?
Any ideas?
