My CH is getting air in it. Has been for years. I used to hav to regularly bleed an upstairs bathroom radiator. I recently put in bigger pipework so that I could turn pump down to 2 from 3, and that has stopped a lot of the air noises, and I can now open bleed screws without it sucking. But now it does this: Early in the morning, when the CH has been off for some hours, on switch on I hear gurgling of air bubbling up in my bedroom radiator. There is an F & E tank, but the CH is pumped. Interestingly, the CH has the pump on the return just before the boiler ( so it sucks the CH water around the system, but the HW pumps into the cylinder from the flow just after the boiler. I've checked most of the comp joints on valves etc, (although there are some old ones best not messed with).
Any suggestions of what to investigate and change, in reverse order of disruption of course!
