I am new to the forum and new to CH systems. We moved to a large property with c. 15 radiators on a single level operating from an old oil fired boiler. Many of the rads only get hot at only the top 5-10 cm and I was thinking of flushing and refilling with the preventers etc.
I have had some pretty high quotes to power flush it. I would like to take on the task in spring time but not 100% confident.
* Do I need a power flush / demagnetiser or is a hose through good enough? I am prepared to take off most of the rads and hose through individually, as when the system is drained, I also want to replace the TRVs.
* I can see the drain valve on the return pipe but what about refilling - will it automatically refill?
* Where do I insert the cleaning and inhibitor chemicals?
* Can I expect any additional heat output / efficiency?
The boiler has a hot water cylinder and feeder tank in the loft and four pipes to the boiler, two for the CH and two connected to the water cylinder, five pipes going up from the cylinder to the loft. I have not looked at the header tank in detail.
I have had one rad off already and quite a bit of black sludge came out when cleaning.
I have so many questions relating to the system but thought best start with hopefully simple first post! I am deterimined to get the most out of the existing system, insulation and control before throwing money at it for a new boiler.
Thanks in advance for any advice.
