I have problem with CH not coming on. I have tracked the problem to the 3 port valve (L&S MAV322). I've checked the two micro switches and these are OK. If I activate them with blade of screwdriver they turn on the CH. I've removed the Synchron motor and tested it - it works OK when connected to mains directly. There is power on the PCB for the motor. I have checked with meter and it's 240v. However it won't power the motor. When I check voltage with motor attached it is about 120 - 130v. Do I have a problem on the PCB? Can I get a replacement PCB for this model valve? Any help welcome.
