CH works but hot water dribbles
27 Nov 2006
Gloucestershire
I have a Ideal Classic Boiler (NF 50 ?)
Central heating system works fine.
However luke warm water only comes out of tap for a short while before
stopping (same on all taps in house and nothing has recently changed)
Turning taps off for a while and then on again allows taps to flow again briefly.
I First noticed reduced pressure on taps a few days ago,but problem is now worse.
Hot water cylinder is hot and both header tanks are full of cold water.
What I believe to be the hot water supply coming out of the top of the tank is also hot.
Previous occupants had a problem with the cylinder leaking about 8 months ago.
Do i need a plumber or a central heating expert ?
AIr locks don't happen by themselves :confused: . Check header tank for sunken dead squirrels etc.
Or perhaps the ballcock might be sticking
Thats if the Squirrels not playing silly buggers :LOL:
header tanks are clear and have no debris in them
Did have a squirrel in the loft once , but it seemed to want to chew up the
wooden ceiling supports rather than throw himself in the feeder tank. :LOL:
Thinking back I might have closed off the feed for the tank just above
the cylinder , which might have caused the problem. :oops: :oops:
