I year ago I bought a house with a Chaffoteaux Britony SE80 (dont laugh). At the time the boiler wasnt working - when it tried to light it would lockout after a while with a flashing 60 degress LED (the manual says this is a fault with the Ionisation PCB). Anyway, about 1 time in 30 it would actually light. I stipped it down, cleaned dust off the pcb etc (obviously never been serviced given its general state). Somehow, the boiler started locking out less frequently, and eventually started running without any problems. Since then, it has locked out only a few times, and in the last 5 months or so not at all.
Anyway, 2 days ago it locked out again with the same error. The next day a couple more times, then yesterday it stopped working entirely, all with the same error code. I've measured voltage to the ionisation electrode at 24v when it is trying to light, so there seems to be no issue there. The spark generator never fires, so my guess is this is the problem. It's not the electrodes as there is never any voltage at the generator spade terminals, and if this actually fires without the spade plugs in, it arcs across the terminals. Currently it isnt doing this. The pressure is OK at around 1 bar cold, the fan runs without a problem, pump is fine. I havent managed to measure any voltage at the gas valve currently however - when should this open during the firing sequence?
I'm guessing the PCB is dead or intermittent at best, but I dont want to pay £120+ for this until I'm sure. Although I don't have the luxury of time given the prospect of cold showers! Can anyone suggest anything I can do to find out more, or what might be wrong?
Many thanks
Ben
Many thanks
Ben
