Help
I have just moved into my flat. It has a C&M centora condensing combi. Probably been switched off for past cople of months.
I switched it on at the fuse spur and at the boiler. It fired up on heating but when i ran the hot tap i got the code 07. It then did this on heating.
The manual that i have says " No water circulation in primary circuit" . The boiler pressure was a little low 0.7, but i topped this up to 1 bar. The isolation valves underneath the flow and return are open (i havent/dare not touch those). I have also bled the rads and a good spurt of water came out there. Cold water with good flow from the hot tap.
Any ideas how to resolve this fault or what is causing it.
Many thanks
Tom
Many thanks
Tom
