Chaffoteax Celtic FF Combi.
Problem - Hot water flow rate has to be 'choked' all the time to get a hot flow.
As this boiler seems to just keep on going, I'm reluctant to replace it at the moment.
I have replaced the main heat exchanger with replacement spare. Fired up the boiler and no discernable difference with hot water flow rate. Still disappointed with result.
Took all pipe work apart around the flexible hose connecting pump and got rid of quite allot of black sludge etc. Started to think I was getting somewhere. Put it all back together again, same disappointing flow rate.
In desperation I have taken the secondary heat exchanger out from the boiler and brought it home with me tonight to try and descale it.
Can this be done successfully?
On first flush under the kitchen tap, clean and seems ok.
Then tried caustic soda (that's all I had in the house) more black crud, then I tried lime scale remover, all now running clear.
When I put it all back together tomorrow is there any other part that needs cleaning that I have missed.
Rads get really hot, but this hot water flow rate is so slow.
These boilers are so basic, I quite enjoy taking the bits apart to see if I can repair it, sad I know............
Any comments much appreciated.
