my boiler is firing up but the 2nd stage ignition will not stay on long enough to heat the water for a shower. it will keep on reigniting but it will not stay on. it does the same thing with the heating too. i have had the boiler looked at by first action they failed to fix the original problem which was a blocked dhw heat exchanger. this was replaced along with the 3 way valve and the circuit board. the boiler worked fine up until recently i have flushed the system and the water is coming out clean so no sludge or black soot build up. does anyone know what could cause this ? is it some sort of timer setting or a temperature regulator or something like that. Also if i need a new boiler can it be installed in an upstairs toilet ?
