chaging central heating pump
16 Jan 2010
Birmingham
hi there. could enybody help me plz. my circulation pump as packd up.its a smc cabet s 50hz .i nw im going to have to get an adaptor to make it fit as mine is 160mm long.but not sure wot pump to get and were i can get it from. could enybody plz advice me :D
Grundfos or any 15/50 will be ok as a replacement. Screwfix, B&Q, any plumbers merchants will have them, although Grundfos is probably the better choice IMO.
I doubt the valves either side of the pump will close off sufficiently for you to change the pump without draining the system though, depends when they were last used! If you are going to drain down, may as well replace both valves and alter the pipework to suit the new pump.
