- Joined
- 24 Aug 2009
- Messages
- 2,680
- Reaction score
- 282
- Country
Today I set out to do the above. It was only the second time I have ever changed rear pads on a car needing a rewind tool, and the first time I used a pair of circlip pliers as I didn't have the tool: as I recall it was laborious but went smoothly enough. Following that I bought a kit for the next time which was today.
I started off using a ratchet with the corresponding tool , rather than the T-bar tool they supply. I sat there turning and turning - and keeping as much pressure on as possible - but noting seemed to be moving. I then came into the house and looked at a video how to use the correct tool and saw my error: just not able to apply enough pressure constantly to the piston. When using the correct procedure with the T-bar and "lock-plate" everything went a lot smoother.
Two questions: I persevered initially with the ratchet because I thought that if there is a thread, then the screwing motion ought to engage it, but it didn't . Why not ?
Secondly, why is this mechanism used ? Why can you not simply squeeze the pistons back as is still the case with the front brakes ?
