Hi folks,
we have been having some trouble with our heating system for the last few months.Main things were the rads getting hot when we put on the HW. Thanks to google and the knowledge on here I diagnosed it to the old spring return ACL motorised valve. On checking both of the 2 port valves both had seized up solid I managed to free off one as it's like new for now however the I snapped the spindle of the CH valve. This was a 5 wire ACL spring return type.
I have now replaced it with a new (old) sunvic sm5201 4 wire MOMO type.The issues I am having with it are regarding the wiring. On looking at it and reading on the internet I beleive I will have to add another wire from the room stat as the old one returned under spring pressure and this one will need a feed to the other micro switch to close the valve so to speak.
We have a honeywell T40 room stat which is wired up as follows.
terminal 1 = Live
terminal 2 = Neutral
terminal 3 = Switched live to valve
How would I need to wire in the sunvic valve with regards to adding new wires etc.Should the T40 be earthed as currently it's not.. we had the house rewired a few years ago but on closer inspection the sparks chose not to rewire everything which included the room stat so it still has the old red/blk wiring.
I have checked the room stat and I get a +ve feed out of terminal 4 when the stat is closed /turned down.
Thanks for taking the time.Any help is greatly appreciated
Which wire off the sunvic fires the boiler? as it was the orange wire off my old ACL valve.
terminal 1 = Live
