Changed thermostat but programme timer not working,ideas?
22 Oct 2011
Bedfordshire
Hello everyone
in an attempt to reduce my heating bills I have just installed an programmable thermostat: replacing an old analogue honeywell with a new honeywell cm901.
The thermostat is working just fine but the programme timer is not working, the timer is stuck on the time that i changed the thermostat, so no coincidence there!
In accordance with the wiring diagram I no longer use the neutral wire (blue) but the live (red) and switched live (yellow) have been wired to the thermostat.
I guess that i have interrupted the circuit to the programme timer, but i don't understand why nor do i know how to rectify the problem.
does anyone have any ideas?
Further information available should you require it.
thanking you in advance
SV
The clock in the CM901 is battery operated; nothing to do with the mains.
Open the lid and make sure you have not left the slider in the DATE position; it should be in Auto.
hi
thanks for your response, the thermostat is just fine and is on auto; it's the programme timer that has stopped. The HW and CH is on 24hours, but i can't use the HW CH twice option as the mechanical timer has stopped.
I'm trying to understand if the change in thermostat is the cause of the clock timer to stop?
