I'm changing my bathroom light fitting. My old one had a load of connectors within the ceiling rose but the new one is just a metal housing with basic connectors for the actual lamp. I've connected all the wires accordingly with plastic connection blocks but the only place there seems to be space to keep them is in the hole in the ceiling, leaving the wires for the light coming through into the housing. I got the light from Homebase but the instructions seem to assume that you only have wires to power the light and don't have extra loops to power fans etc. What should I use to safely connect it all up and where should I store the connectors? (The loft above the ceiling is boarded)!
____________________________
moderator
moved as posted in wrong forum
moderator
