Took down two old hallway light 1 and light 2 ceiling roses to replace with two new light fittings. Both lights were working before, both lights are controlled by the same switch system(one downstairs one upstairs). So managed light 1, but got carried away and forgot to mark switch wires live from the old light 2 rose before removing!!!!!!
There are four two core wires each with red black earth, I'm calling these A,B,C,D.
Took ohm reading for each.
Wire A - Low resistance & no change when flicking lighting switch - What does this do connect lights or switches I'm thinking, this is wires to light 1 rose which should cross over (live to neutral, neutral to live) ???
Wire B - Low resistance then High resistance when flicking switch - This is the switch wire ??
Wire C - High Resistance - Loop wire in or out??
Wire D - High Resistance - Loop wire in or out??
To confuse me more, wiring on the light 1 has a black and red from two different wires of the four that are wired to the lights brown live connection, remainder three reds looped and three black to blue neutral connection on the light fitting. I think I remember this was how light 2 ceiling rose was wired but which wires!
Tried many different arrangements but can't get it wired up correctly. Best I can get it is wires B Black switched live to Brown light fitting B,C,D reds grouped to live loop then B,C,D blacks grouped together A red left isolated - so light 1 works and so do the rest of the looped downstairs lighting circuit, but obviously light 2 not. If I put A red into switched live then circuit shorts if switch turned on. How can i test what wire A is?
I have an analogue multi meter and a voltage screwdriver tester.
Please advice as it all worked before I tinkered and the circuit hasn't been altered!!
