Hi
I'm in the process of installing a Fluidmaster Dual Flush Valve. I have turned off the water, emptied the cistern, undone the screws connecting the cistern to the bowl and have come to removing the nut from the inlet pipe. However, when I turn the nut the whole inlet valve inside the cistern turns. Does this mean the valve and nut have been glued together to stop any leaks or do I just need to use brute force. I don't want to force anything unless I'm sure it's OK to do so.
Any ideas?
Any ideas?
