Hi all,
I need to replace the lintel in the middle of the above picture. The builder I would normally use isn't available anytime soon and the job needs doing so I'm looking at a possible DIY effort.
I've got the structural calcs which specify a 152x89x16 rsj, it doesn't specify the length, the span of the room is 250cm and I'm assuming 15cm either end will be sufficient. He has specified the padstone requirements I'm happy with those, hoping the bearings for the old lintel will be the same spec
My questions are regards doing the actual job, my thoughts are 3 acrows with boards on each side of the current lintel supporting the ceilings (6 in total)
Remove old lintel
Support the wall above lintel with a board and acrows while doing the required works to the walls that will take the new rsj ends
then remove the centre acrows and boards, slot the rsj in and resupport with acrows while packing the padstone joints?
Make good with pink plaster board and plaster before decorating.
Does it sound like I've missed anything there? I was thinking of having timber added to the rsj webs to give something to secure the plasterboard to.
Chris
