I shouldn't really let you get away without a better explanation, but if you insist on changing whole valve, here goes.
First you need to see if you can isolate the section of pipework on which the valve is fitted. If it's after the pump, the pump isolating valve will allow that side to be isolated. If you're very lucky, a thoughtful installer will have also placed isolating valves on the HW and CH branches, in which case its all very simple.
More likely you will have to drain and refill a more substantial part of the system, depending on the relative positions of valve, isolating valves and drain points. You have to work that out for yourself.
One drained, the 3 compression nuts can be undone and the old valve replaced (with the same make to allow reuse of existing nuts and olive). the wiring should be the same as before, so replace each individual cable one at a time.
