Hi our triton Jade 2 eletric shower has finally bitten the dust and we are looking to replace it with the Jade 3 as the connections are all in the same place so hopefully it should be fairly straightforward as we are looking to do it ourselves. I just have a few questions I want to check.
The cable looks to be 10mm and it is on it's own separate circuit, there is a 30amp rcd on it too so I presume the electrics are ok as I am not upgrading the power of the shower!
The existing shower is connected to the cold water main by a compression elbow joint, I presume I can use this again and just use a new olive, the inlet on the shower is plastic is that ok to use an olive on?
I have read that the cold water pipe needs to be flushed to remove swarf, is this still the case if it is an existing pipe or only for new ones?
Is there anything else I need to take into consideration?
Many thanks
Many thanks
