changing an immersion cylinder
10 Sep 2009
Norfolk
when you change an immersion cylinder do you drain the heating system from a rad drain off or is it easier to crack the fittings to the flow and return on the coil and catch the water there.
Drain from a proper drain off below the height of the cylinder. You'll be there all day trying to do it the other way :D
