Changing Batten LaMp Holder
9 Aug 2011
Hampshire
Hi i need some help in changing a batten lamp holder, though it would be easy as there is only a red and black cable going into it. But i think i havee brought the wrong one as i got a loop in one and connected the cable but it does not work? Which one should i get a non looped in?
I have attached a picture
YOU DIDN'T SAY YOU SENT A PHOTO ON YOUR PROFILE.
IGNORE EARLIER ADVICE AS IT'S NOW OBVIOUSLY INACCURATE.
One of those terminals in the picture will be a loop terminal. The other two terminals connect to the two pins on the lampholder which make contact with the lamp (bulb).
You need to connect the live and neutral to the terminals that connect to the lampholder pins.
Either way round, unless the terminals are marked.
From your picture, it would APPEAR you have wired it correctly, so it should work.
EDITED FOR TALKING ABOUT A MODERN CEILING ROSE TYPE LOOP-IN BATTENHOLDER.
sorry the picture is of the one want to change.
I connected the new one to the terminals (not using the looped one) and it does not work?
Right!!!
Is your new batten holder the 'ceiling rose type', with three brass connectors in a row along the middle?
If so, earth wire(s) go in the seperate the earth terminal.
The brass terminal at the end of the row with two holes is for the live from the ceiling, and the live flex from the lampholder.
The middle brass terminal block gets left empty.
The brass terminal at the other end is for the neutral from the ceiling, and the neutral flex from the lampholder.
You'll have to send a photo of the new battenholder if I have misunderstood you.
Seems strange you can't get it to work, so let us know.
Hi guys thank for the help
All fixed the bulb was also faulty as only worked in a certain position, from where it had been knocked so all fixed
