- Joined
- 11 Dec 2007
- Messages
- 400
- Reaction score
- 2
- Country
I think that's the exact model that it is (the clarke in the title). Basically i just want to know how to put it on (properly).
The old blade snapped so i got a new one in from machine mart & had a go at changing it. I think i figured it out right. I slackened off the top wheel & fed the blade on making sure it was central on the wheels (as best as i could). The blades teeth were pointing downwards.
I then tightened it up as much as i thought was ok & checked the blade moved 'straight' through the guide (i'm calling it a guide but i'm not sure of it's proper term - the bit where you cut).
Started it up & there were a few sparks around where you would cut but this stopped soon enough.
I cut about 4 test pieces & all seemed well until i started hearing a quick change in noise so i quickly stopped it, opened it up to find the blade had almost slipped off the wheel both top & bottom.
I'm not sure what to do so i'm asking here. I thought i'd tightened it enough. Am i supposed to tighten it as much as i possibly can? But then can't you overtighten & put too much strain on the blade?
Help welcome.
Help welcome.
