Do you mean change from vented to unvented? If so, it's not a DIY job - you need a new hot water cylinder, some safety valves and a fair bit of plumbing by someone qualified and registered to do such work. I didn't need any work to the pipes into my bathroom when I had mine converted. First thing you need though is the flow and water pressure checked to see if it can be done.
Are you converting to a Combi boiler, unvented cylinder, or something else? Elaborate more on what you want and we can elaborate more on what to advise.
Sometimes you just can't! Tell us why and get your incoming mains tested... Preferebly at the suppliers stopcock first, which can "often" be provided upon request to your water supplier.
we don' t want a tank in the loft and heating systdm is 35 years old in thd house we are buying.
so iwas wondering with cold water straight from mains and hot from a combi would existing
pipework to bathrooms cope with the new pressure?
