- Joined
- 21 Jan 2018
- Messages
- 6
- Reaction score
- 0
- Country
Hello. A particular dimmer switch in my abode broke the other day, I decided to just buy a standard switch from wickes as a replacement. The switch only operates the one and only light in the room so I thought a pretty basic switch would do the job, when I was looking on the shelf they only had one plastic single switch, it didn't say anything special, so I bought one, brought it back home, killed the power at the fuse box, unscrewed the old dimmer switch and was presented with a problem.
It appears I've bought, no thanks to wickes for completely failing to put it anywhere on the packaging or the label in the store, an intermediate switch rather than what should probably be a simple one-way switch with the same terminal Layout of L1 and C.
The dimmer switch has three terminals, L1, L2 and C. Inside the wall mounting are three blue neutrals terminated, three earths also terminated, and three brown wires; one was in the C terminal, the other two in L1.
The new switch I have bought has four terminals, L and N out and L and N in as well as a couple of earth points (which I believe I don't need to use as the plate isn't metal). I tested the wires with the power on and found only one of the two that was wired into the L1 terminal on the Dimmer had the AC voltage and the rest didn't have any voltage (actually they did but it was <1v and possibly a result of my multimeter being a bit thick).
For clarity, I've made a crude drawing in MS Paint of how the dimmer was set up and what the new switch terminals look like:
Am I correct in thinking that all I need to do is stick the two brown wires from L1 into L OUT on the new switch and the C wire into L IN? Or would that blow a fuse?
