changing metal to plastic, no earth
8 Mar 2006
Hello, I'm replacing metal light switch covers with plastic ones - the back boxes are still metal, and there is no grounding thingy on the new plastic covers. What do I do with the earthing wires inside the metal back box? Do they still need to be connected to the new plastic covers?
There should be a terminal on the metal backbox to connect them to, if its missing I suppose you could use a self tapping screw in the back of the box
Thanks! But I don't understand... the earthing wires are connected to the back box, but there is no place on my new plastic switch covers to connect them. Some guides say that if using a metal back box, the earthing wires should always be connected to the cover - some say a plastic cover doesn't need to be connected. help?
a plastic cover doesn't need to be connected to earth becuase its not conductive, a metal one is conductive and does need earthing, eitherway the backbox needs earthing (unless nylon scews are used), if a metal switch is used, this is earthed and this earths the backbox through the screws (belt and braces approach would be to fit a wire link as well), if cover is plastic, you just connect the earths to the backbox
Great, thanks again. So about the existing green/yellow grounding wire hanging out fo the box (was attached to the old metal cover until 2 hours ago) - do I cover the end with tape and leave it in the back of the box?
Sorry - I don't usually do DIY!
