I would like to get some solar generating going and like to get things done under my own steam however I respect electricity enough to bring in help where I need it. Basically I want to power my lighting circuit (whole house on one circuit) in my 3 bed semi using solar PV with the option to switch it back to mains again. I am working on the basis that I will get a few panels and a bunch of batteries, I will then replace those bulbs I have that are not low energy to bring down the total wattage of the house. I should have around 16 11 Watt 240 Volt bulbs all together (we are sparing on our lighting usage anyway).
So wiring up the panels and the batteries will not be a problem for me and getting them ino a reasonable transformer will be OK. What I cannot get my head round is the way of swapping between solar and mains. I recently had a UPS fitted at my work for my fileservers and have an isolating switch on the wall that allows me to seamlessly transfer between mains and UPS power which is essentially the same principal...
So, really - anyone done this? Advice on the switch I need? Is it legal (of course, I will get someone to part p and do the switching part) Just how much battery storage will I need to cover 6 11 Watt Lightbulbs for 7 hours (based on winter usage 17:00-23:00)
PS - For those other questions:
1. Solar hot water not much good - I do not have hot water tank and only two of us we really don't use that much
2. 12V - no good since do not want cost & complexity of dual circuits and having to worry about voltage drop so much.
3. I can get solar panels for £1.25 per watt (providing I make them myself) so getting 200 Watts or more will still be quite cheap)
4. Cannot be bothered or afford complete grid connected system as it will not cover my usage and the government does nothing to encourage us mere mortals to move to solar / alternative.
