changing my outside light fitting
5 Apr 2006
Cambridgeshire
please can someone help? The other day I changed my outside light fitting. The house is only 2 years old, & I've been in it about 10 months. The old light was a 12 watt piazza light. I removed it, & I have 3 wires coming from the wall: 1 red, 1 black, & 1 green/yellow. From the new light I have: 1 brown, 1 blue, & 1 green/yellow. I connected it up, brown to red, black to blue, & green/yellow to green/yellow, screwed in the sixty watt bulb, & flicked the mcb back on. It tripped instantly. Now my light wont work. For some reason the light has no switch. It is run straight off a PIR. The PIR is clicking on & off, but the light wont light. Please can someone tell me why the mcb tripped. I wired the exact same light up to the back garden, & it works fine. ( no PIR at the back, just a switch). I've bought another light but dont want to wire it up yet, incase I do the same. PLEASE HELP!!! cheers.
Perhaps the bulb was damaged in transit, and burned out in the first moments of use.
i've tried it with a bulb i know works, but still nothing. I've also tried a normal bayonet light fitting, but nothing there either.
In that case something has fused inside the lamp or the PIR, and the inrush at the moment of fusing tripped the MCB.
At a guess...
Dunno - all we know so far is that a 12W was OK, and a 60W might have b*gg*r*d it.
Was the 12W one working before you removed it? Do you still have it? If you put it back, does it still work?
yes the old light worked before I removed it, but its a new light fitting, with a standard screw in 60 watt bulb. The old fitting had a 12 watt push in bulb, shaped like an M
Try swapping the fitting back and see if it still works.
Or try getting a new PIR.
Mind you - I don't think anybody makes a PIR that can't cope with a 60W load.....
Are you able to measure the output from the PIR as it switches on and off?
the pir still works, as i can hear it clicking on & off. One thing I have noticed is a fitting inside the house (behind where the outside light is, but at floor level) with a blanking plate on it. do you think that could be the switch for the light.
no. its a blanking plate. not a switch. Its probably a junction box for something.
WTF is a pizza light? i'm thinking a flat round lamp of some sort . . .
