Changing my thermostat from honeywell T6360b to Cm921
22 May 2009
West Midlands
Hi all
I have a T6360b which has 3 wires and i would like to change it to a CM921 which has only two on the wiring dirgram how can i change this.
help please
T6360b
1 - Heating live from programmer
2 - Neutral
3 - Switch live
CM921
N - Neutral
L - Live
A - Live
B - Switch live
seco
am i right,
original 1 wired to L
original 2 wired to N
link fom L to A
original 4 wired to B
The T6360 was just a thermostat; the CM921 is a combined programmer and thermostat. If you connect the wire which was on stat terminal 1 to L you must set the existing time switch to CH always ON. Alternatively, and I think the better way, is to find the other end of the wire connected to terminal 1 and move it to a permanent live; the existing CH timer is then completely bypassed.
