hello,
I currently have an ideal 2000 boiler doing my central heating and hot water. It only has 3 pipes going to it, i assume gas outlet and return. I have a motorised valve in the airing cupboard, with a common and two outlets, one side for heating the other for hot water. I am assuming that my hot water is heated through a coil in the tank because I only have 2 water pipes coming out the boiler. I also have 2 big water tanks in my roof space, and an electric pump in the airing cupboard.
what I want to do is convert to a combi (been told Worcester are best?).
I THINK thank the heating side of it will be fairly easy, use the existing two pipes I have from the boiler, take out the 3 port valve and just connect the common to the heating side, and completely remove the hot water side and my expansion tank.
does this sound ok so far??
As for the hot water, this is what im most unsure about, the boiler is mounted fairly close to my kitchen sink, so would it be possible to take the cold water supply from the supply to the sink? and as for the hot water out, could i just T into the hot water pipe to the sink and then that would charge the whole hot water system???
I hope this is how it could be done, if not then its going to be a major job. Could someone please tell me what they think about this, am I on the right lines or does it need to be done another way?
Any help will be greatly appreciated
Cheers
Cheers
