Changing old central heating programmer
1 Jan 2008
Kent
Although c/h boiler replaced couple of years ago, the original Sangamo Western Timer was not (cant find any model number outside or inside) - its about 35 years (or more) old with pins that are inserted into the clock face to provide 2 on/off cycles a day and has 2 large switches that give (1) manual/off/auto and (2) heating and hot water/hot water. We have pumped c/h and gravity hot water with 1 room thermostat and no cylinder thermostat.
This timer has 8 wiring connections of which L, N, 5, 6, 1, 2 & 4 are used.
All modern timers seem to only have 6 connections.
Any ideas as to how I can connect one of these new timers?
The only way I can think of is to forget the numbers on the wiring terminals and trace back/find what each wire is connected to and controls.
Once you know this it is then a simple matter of following the new programmers wiring guide.
Use of a multimeter will be required.
you dont say if the original timer is broken.
like gas4you says i would trace it back. most of the time the experienced will know immediately what wire is for what from memory or hunch. if you dont have a multimeter just apply 240 to each wire and see what starts up.....ch or hw.
your new timer will only need hot water only (boiler feed) and heating/water simultaneously (boiler feed, valve/pump feed) and mains feed of course.
im willing to bet the old timer will have links from the mains feed to common switches for ch/hw and switched lives from them to the boiler etc. the new timer wont need the links.
mark everything before you start so it can go back together!
Thanks guys - managed to get it all sorted with your advice - after the initial panic it was quite straight forward!
