Hi hope you can help.
I previoulsy had an extractor fan in my kitchen that would come on when the light switch was switched on and stay on for a timed delay afterwards. It was old, noisy, covered in thick grease, so I have removed it and would like to fit a new fan. I want to fit a separate switch for the fan so that I can switch it on and off at will, rather than it coming on and staying on whenever I simply want to get a glass of water or something like that! Its very annoying.
Currently, coming out of the ceiling where the old fan was are three wires - yellow, blue and red.
Up on the wall above the switch is a 3 amp switched socket with the following connections:
At the top of the fused socket marked under "feed" is a two black wires into neutral - one wire goes up towards the ceiling - feed? the other goes down the wall towards the light switch.
Two Red wires in the Live - again, one up to ceiling, one goes down to the switch.
Then below these fittings there is a Neutral which currently has the blue wire from the fan and a black wire which I assume is the neutral for the ceiling light?
Then there is the Live connector where two red wires are connected, one goes up to ceiling again I assume for the light and the other down to light switch.
The yellow wire from the fan and a black wire with red sleeving coming from the light switch are connected up in a block and taped up.
In the light switch there is a black wire with red sleeving connected to the No 1 connector, red in common and then two reds and two blacks both joined together in a blocks and taped up.
The new switch is a 2 way switch with two switches, both with common, L1 and L2 connectors.
Can anyone advise on what I have to connect to split the lights and the fan up to this new switch? I take it I will probably have to put a new cable in from the fan connectors to the switch?
If its too hard I will get some one in to do it.
Thanks.
Thanks.
