Changing only chandelier fitting
17 Apr 2020
Hi, I am looking to change this old light fitting. But when i unscrewed the fitting, there was only this brown wire you see, going up into the ceiling hole. and when I pull, there is tension, so I feel I should not pull any further. But this is the lighting cable, and I can't locate the part where this wires into to change the light. Any help?
I expect someone has raised the floor above and fitted a junction box under the floor.
Can you raise a board above?
Or else they have bodged it with a bit of terminal strip and pushed it up into the void!
If the brown cable is in good nick what's stopping you cutting the brown cable and using a wago box to connect to the new light?
