Changing the Light Fitting
18 Dec 2007
Apologies if this question doesnt fit this area.
I want to replace the light fitting in my kitchen. On removing the old fitting I see the plaster around the hole from which the live/neutral wires come isnt too firm. This is making it difficult to fit the bracket for the new fitting.
I thought I could fit a small plate of sufficient size which will reach to better plaster and allow it to be fitted securely. Drilling a hole in the middle of the plate will allow the electrical cables through for connection to the new light. The new light fitting bracket can then be secured to the plate and the light fitted. The job can be finished with a bit of paint on the plate.
Is this the best way to do this? Can I buy a small plate (wooden?) from B&Q etc? Is there an alternative method?
Thanks and grateful for your help on this.
If this is a pre-war house (lath and plaster) you may be able to fix to a lath.
There may be a noggin or joist nearby to fix to. You may be able to fit a noggin by lifting a floorboard.
Are you fixing to old lath and plaster, or newer plasterboard?
Spring toggles can provide a reasonable fixing, but not if the ceiling is as crumbly as you suggest.
In answer to the original question, yes you can get something at B&Q.
They do small wooden decorative plates for fixing bannisters onto the wall.
It isnt a pre-war house. 1970's maybe? I presume its plasterboard, not sure.
How heavy is the light fitting?
Unsure of the weight as the package doesnt giv details. It is made of tube steel with 4 small downlights attached.
Sorry to be so lacking in detail :oops:
Thanks for your help.
Thank you for your help.
I think this may be the best way to proceed. :)
