Hi experts
I have just purchased a Honeywell CMT921 to replace my broken T6360B.
I found a thread here //www.diynot.com/forums/viewtopic.php?t=179838 with info on how to wire up the CM921.
However, when I opened up the T6360B I found mine only has 2 wires (instead of 3 - as per the mentioned thread).
The current wiring on the T6360B is as follows
1 - Coming from 4 at boiler (I assume live)
3 - Coming from 3 at boiler (I assume neutral)
(Boiler: Vaillant ecoMax 828 2e combi boiler)
Can anyone provide info on how I would wire up the CMT921?
Having looked at the manual, the obvious solution (to me) seems to be:
4 (from boiler - which I assume in Live) goes into B in the CMT921
3 (from boiler - which I assume in Neutral) goes into N in CMT921
A (on CMT921) connects to L (on CMT921)
L (on CMT921) connects to L (on CMT921) - there are two L sockets on the CMT921 - do I need to do this or does the CMT921 already have an internal connection between the two L sockets?
Does this look right to the experts?
Giz
Giz
