Hi
Just redoing the bathroom, following shower breakdown and leakage, and we are going to replaster the ceiling and remove the old light while doing so. I am planning to get 4 of the flameguard ip65 downlights that come highly reccommended on here. Was going to get the mains voltage 50w lights. There is a 4 way junction box in the loft already leading in and out of the circuit, off to the light and off to the switch, if I remove that light connection can I just wire each downlight into the same connection on the JB (same connections the old light used) 4 50w downlights should be ok coming off the pull switch?
thanks
thanks
