Hi all
I am looking to buy a relatively cheap bench mount bandsaw.
My current shortlist is:
Charnwood BS410
Record Power BS250
As someone with very little experience of bandsaws-
The Record has a longer warranty and the fence can support less tall stock. Customer feedback says that the shipping packaging is inadequate and the saws often arrived damaged.
The Charnwood has a belt tension guide which might be useful for a novice, depth of cut is 20mm less but the motor is bigger. I can't find many reviews though. Oh, and the user manual looks easier to follow (TBF, RP do provide DVDs as well).
The primary intended use will be for trimming timber for splicing sash window repairs on site. I will be way under Charnwood's 100 hours usage per year warranty.
My primary reason for selecting these two models is that they are the only ones I could find sub £300 that have two side facing bearings and a rear thrust bearing. Additionally, I can find them both in stock (there seem to be supply shortages in the industry). The RRPs are the same but I have found the Charnwood on special for £240.
Advice/recommendations will be gratefully received.
Charnwood BS410
Record Power BS250
